[SOLVED] Fractal Design FD Case Worth It?
thewalleprod
165
I have an Antec 900 case at the moment and it's good and all, but it's just too heavy and too big for what I'm trying to achieve. I wanted to downgrade to a lighter and a little smaller case and I came up on the Fractal Design FD case for $50 on Amazon. It looks nice and it looks like it has solid air flow. My question is, will this be too tight for my components that I have at the moment?
Here is a link to the case itself..
https://www.amazon.com/Fractal-Design-FD-CA-Focus-GY-W-Computer-Gunmetal/dp/B074PTNZ7F/ref=sr_1_4?s=electronics&ie=UTF8&qid=1548177844&sr=1-4&keywords=fractal%2Bdesign&th=1
Components List:
i7 6700k
z170 pro gaming motherboard -- asus
gtx 1080
two ssds
850w power supply
If this will be too tight for the components, can someone recommend a smaller/lighter case that will fit everything properly.
Thank you!
I thinks is a nice case, a bargain at that price.
Very good GPU and cooler support.
Very good air flow with removable dust filters everywhere.
If you had a smaller motherboard (Micro ATX) you could have gone with an even smaller case.
