[SOLVED] Fractal Design Meshify 2 and RGB fan questions
Bob1nba
195
12
4,585
I bought the Fractal Design Meshify 2 for my new build and plan on getting RGB fans for it. I already bought the Nzxt x73 kraken rgb AIO to be mounted up top, but was planning on replacing the front fans with 3 Lian li rgb unifans, along with one in the back. With how the case is designed in the front with the mesh, can you see the rgb fans well? I've tried to find pictures of a build in this case to see if anyone did this but couldn't. Thanks .
https://pcpartpicker.com/b/sCWbt6
Edit different fans but you get the pictures.
Thank you! Also will it make much of a difference if my 3 front fans and 1 back fan are different than the nzxt kraken rgb fans that come with it? I just don't want it to look stupid with two different fans. Guess I could always shell out more cash and change the aio fans to the lian li as well. But that would be another 105 dollars lol
They will look different and probably not sync.
Yeah so looks like I'll be shelling out the extra money. Whats a little more after what I've spent already lol. I guess I could just resell the aio rgb fans and the 3 that come with the case and get something for them
