Fractal Design Node 202 max PSU
eXoguti097
Commendable
Oct 23, 2016
12
I'm planning on switching to a this mITX case and I know there's definitely some restrictions. It would probably be fine but I have an i7-6700 and an EVGA 1080Ti SC2. I'm doing well with a non-modular EVGA 600W PSU but I have no clue if it will fit. The case specs say PSU up to 130mm in length. Looking at videos, it seems like the rest of the space fits cables, maybe it can fit a slightly beefier one? Also, I definitely wouldn't want to use my non-modular psu, so what is the lowest I should go for my parts to try to find a modular one?
Despite Fractal Design claims the case to have a max PSU depth of 130mm, you can actually buy it with a premounted Fractal Design Integra SFX 450W PSU. This (fully modular) PSU has a length of 140mm, which seems to be the max.
The Integra M series PSU also includes 550, 650 and 750W with the same size.
Nigel
