So I've just put together my new PC and I'm using the Fractal Design R4. Everything is working perfectly except for the front headphone jack. Whenever I plug it in, I can hear a static sound and the sound is distorted.
I tried all the obvious fixes such as driver updates, removing HD Audio cable and re-attaching it, re-routing cables, changing audio default devices etc and still no luck. The static and muffled sound is also happening when I plug in different sets of headphones. There is no issue with the back panel headphone jack.
I've done a little research and haven't found any other fixes and was wondering if anyone has any suggestions or fixes.
PC SETUP
CPU - Intel i5 4690K
GPU - EVGA GTX 970 OC Edition
MOBO - ASrock z97 Fatal1ty Killer
RAM - 16BG Kingston HyperFuryX
PSU - 750W EVGA SuperNOVA
Case - Fractal Design Define R4
Thanks in advance
(PS sorry about the format if its an issue, first time poster)
PC SETUP
Thanks in advance
