Fractal Design R4 vs NZXT Phantom 410
whatisapc
14
I was thinking of getting the NZXT because of how amazing it looks but now that I have seen a couple of builds that include the R4,it makes me want to get it too.I have heard the r4 is really quiet so can you basically just list the PROs and CONs of each thanks.
In my honest opinion the NZXT Phantom looks AMAZING and has really good features as well. I would go for that one. As for your comment about the Fractal R4 being really quiet, there really is no difference is noise between the two cases. Each of them have brilliant airflow and watercooling options.
There is a substantial difference in terms of noise between both as the Fractal R4 has noise dampening material on both side panels. If you want a quiet PC case which provides very good airflow then get the R4. If you want a PC case which looks damn fine and also provides good airflow get the 410.
I was told the r4 has bad airflow.... by ALOT of ppl
