Fractal Design R5 or Phanteks Enthroo Pro?
blurryy
214
What would be the best case out of these two options:
Fractal Design R5 (Windowed)
Phanteks Enthroo Pro (Windowed)
Both are around the same price..
Specs:
Asus Sabertooth Z87
Can you fit a dual radiator on top? without clearance issues?
Thanks
Yea i have a Enthroo Pro and it is a really good case; easily fits my H100i cpu cooler. I will advise you install the radiator first before you add your motherboard as I have the Asus z97 Sabertooth Mark 1 and reading from other sources they recommend that you install the radiator beforehand which I did and I am glad I did it.
