Hey all,
I've got a Fractal Meshify C with a Kraken x63 and when it boots up, it's entirely quiet but over time, it warms slightly and you can hear the pump working with idle temps beginning at 38°C and after easy browsing, never below 41-45°C degrees.
The build is fast and performs well but I realize that there are some problems with the way the radiator is and it's a bit cramped. It definitely doesn't help GPU temps to have the radiator so close to the GPU and providing warm air directly on it.
Would anyone recommend just swapping out to an air cooling solution for the CPU, to free up more space for the GPU to breathe and ultimately lower temps all round with the front intake fans being able to provide 100% cool air. Also happy to hear suggestions regarding the positioning of components but at this point, I may just look at getting an air cooled solution.
I've currently got an AMD Ryzen 7 3800x if that helps.
Thanks!
Thanks!
