Hi! PC hardware newbie here.
I got my build assembled a few weeks ago by a PC parts shop. I opted to choose Air over Water Cooling mainly due to less points of failure & availability. However, I live in a hot humid country, it's the summer season, and I easily hit 45+degC on idle. My CPU Cooler is the NH-U14s with 1x stock U14s fan & 1x NF-A15 PWM fan. I'm looking to maximize the airflow on my Fractal Define R4 Case. Noise is not an issue.
Hence, I purchased 3x Bitfenix Spectre Pro LED 140mm to use as 1x rear & 2x top exhaust; and 1x Noctua 140mm NF-A14 iPPC-2000 for front intake which can provide good CFM & Static Pressure. I also want to retain the 2 Fractal stock fans that came with the case as front intake and bottom intake fans.
So, installing the fans:
1) I removed the top HDD cage of the R4.
2) I installed the Noctua iPPC-2000 with no problems & connected it to the motherboard fan header.
3) I am confused where to connect the Bitfenix Spectre Pro LEDs; if only the 3-pin connector connector is connected to either: the motherboard or the R4 case fan controller, the fans spin but the LED lights don't work. If I add the connection of the 2-pin LED (+ -) wire, that's only when the LED lights work. This tends to use up to 2 connections for just 1 fan and I think I'll run out of ports/headers before I can install all the fans I want. What is normally the setup in connecting these LED fans? No instructions came with the box. Also, I noticed that both the LED & 3-pin wires get really hot even only after a short time of use - is this normal?
4) I can't install the Fractal R4 stock fan at the bottom of the case as my PSU cables are blocking it. Is my PSU simply too big? Is there anyway I can re-orient the PSU to fit the fan? Same case with the 2nd top fan slot, a cable is blocking it but I have no idea what the cable is.
Kindly see pics here: http://imgur.com/a/Mvc97
PSU: Seasonic G750W
MOBO: Asus X99-A
Thanks!
PSU: Seasonic G750W
MOBO: Asus X99-A
Thanks!
