Question Frame Drops after GPU cleaning with brush
7
I cleaned full pc. and i used paint brush to clean GPU fans and after deep cleaning pc i turned on perfectly booted. But when i started a game i got frame drops, can someone help?
I using Nvidia 1050 TI Graphic Card.
Did you unplug the pc when cleaning it? If so check your refresh rate in settings to make sure it is correct. You could also try reseating your memory and gpu to make sure you didn't unseat them a bit while cleaning your pc. Check your gpu and cpu temperatures while gaming also.
