Frame lock in Unturned
ginningfool97
232
I have reason to believe that there is a frame lock in unturned because my pc has never exceeded 60 fps (I changed the graphics settings from low to ultra and didn't change anything) Now before you say my pc sucks I can play BF4 at ultra 60-121 fps on average so I doubt a game that has a blocky texture can bring it to its knees. I have never seen it go above 60 fps so is something on and I don't know it or is it the max my pc can push? GTX 960 4gb AMD FX-4350 8gb RAM
That doesn't give us much info to work with nor criticize you 😉
Can you please pass on your full system's specs inclusive of your OS? Can you replicate the issue on other titles? If the issue is confined to that one title(Unturned) then you might need to realize that the game either needs a re installation, the GPU drivers need an update or that the game in itself is badly optimized since this kind of an issue was seen when Crysis(I) came out prior to it's updates. Even after updates came out, it yet crippled most high end hardware and at the time was a tagline for meme's and enthusiasts alike.
Have you voiced your concern on Steam as well? Further reading.
