Frame skipping/choppy gameplay (high fps)
CookieJohn
13
The issue I'm having is hard to describe and I don’t know what they call it, so I had no luck searching the forums for the issue. I apologize in advance if it’s already been discussed.
In ANY PC games I play I'm getting rough frame rates. Its not lag or low FPS since I closely monitor it with FRAPS and it records no issues. It's as if every other tiny frame is being skipped leaving the movement jittery. When I move the camera and/or look around it doesn’t seem to be refreshing as smooth as it should be. The stranger part about it is it only seems to be related to mouse input. For example, whenever I move the camera or look at the environment using only keyboard input it seems to be smooth and fine. It also appears to be less noticeable at higher FPS... It really has minimal impact on gaming ability, but puts a very big strain on my eyes after a short bit and is all around driving me crazy. I have attempted many fixes including updating drivers and re-installing windows 7. I don’t have SLI which many people have contributed this issue too.
Yesterday i also played blacklight retrebution and bioshock and when i set the mouse speed to really low all the problems that im having go away. But when i put the mouse speed back to where i usually play the problems come back. It really bothers me because when i check fps on fraps it shows 58-60 fps if i have v sync on other wise it shows 150 fps in the games i mentioned.
PC SPECS:
Asus gtx 970 strix 4gb
MSI Z97 gaming 5 motherboard
Intel core i5 4690k 3.5ghz quad core
1 stick of 8 gb RAM
650 W inter tech PSU
1TB HDD
LCD22WV-BK
Appreciate your feedback!
I think, perhaps, you just see either input lag or micro stuttering.
It could be the side effect of having VSync on.
Try turn VSync off and activated tripple buffering.
You might see screen tearing if you turn off VSync, this is why you should try to activate 3x buffering.
Perhaps this can help.
