Question Frametime problems
waynebouvett
Proper
Feb 4, 2019
59
So i had a new gaming PC and i had i5-8400 and a RTX 2080 then i changed everything because i had unstable framtimes now i have i7-9700k and a rtx 2080 and it's still having unstable frametimes it spikes to around 678000ms this happens to all games that i have.
Rogue Leader
It's a trap!
It very well could be false readings, especially if you're playing something that you get very high average fps in. It also could be if you're using v-sync, or freesync, etc. If you're not seeing the frametime issues visually in game (HUGE spikes like that would cause a visible stutter) then the issue is not there.
Aug 17, 2019
20
I got spikes over 2 milion biggest was 2mln 400k.
My frametime looks same. It look sams but not always. No pattern totally random and I'm freezing sometimes as well
waynebouvett
Proper
Feb 4, 2019
59
i don't think it's false readings because i feel the spikes and the lag like when it's 60 fps it feels like 30 for some reason and when i look around in a game it is chucky it isn't smooth at all
Rogue Leader
It's a trap!
This happens to all games
motherboard = Rog strix z390-f(new)
Cpu = i7-9700k(new)
gpu = rtx 2080(new)
16gb ram(new)
850w power supply
More detail on every part of your system (make model speed etc) . 850w PSU tells me nothing. Nor does 16gb of ram
Are you using vsync, or gsync? Can you video this behavior?
