Archived from groups: alt.games.doom (
More info?)
SnoopJeDi wrote:
> bob brozewicz wrote:
>> "map:air01 idrenderworldload::initfrommap: maps/air01.proc not found
>> game map shutdown."
> Sounds like:
> A) you didn't get all the files extracted (if the mod isn't a .pk4 file,
> make sure you extract the entire archive, not just the .map file)
the mod is in a .pk4 file. i downloed this from several sources figuring
it may have not been complete. all the downloads were identical.
> B) the mod is incomplete (not likely if other people have posted reviews)
> C) The map is not compiled by the creator and has to be compiled before
> you can play it.
> My advice to you:
> Open the archive that you downloaded that contained the mod and read the
> installation instructions (if any) in the readme.
i read the install instruction a few times. there is not much to
installing it.
> Try reinstalling the mod and seeing if that works.
tried this too with no luck.
> Search for the file that won't load in doom 3 in the archive. If it
> isn't there, you either need to compile the map, or it is an incomplete
> mod.
> To compile the map:
> "Start up Doom and type: "dmap maps/yourpathinfo/yourmapname" or press
> the bsp button in the editor.
> That's it. Doom will compile your map in a few seconds and you're ready
> to walk through."
> - Excerpt from
http://www.doom3world.org/phpbb2/viewtopic.php?t=3
> So if your map is named "testmap," for example, go into Doom3, bring
> down the console with CTRL+ALT+TILDE (~ or `) and type dmap maps/testmap
> Alternatively, you can just boot up doom3radiant (either start doom3.exe
> with the +editor parameter or type "editor" in the console), open the
> map, and press the BSP button.
> Out of those three sources of problems, I'd say problem A would be the
> most likely. Try reinstalling following the creator's directions to the
> word.
like i said above. i did this. i may be one of the few that will read in
install instruction before i even think about installing any thing, not
just doom 3 mods.
> Good luck!
