Fraps recording lag help
steven37
283
sometimes when im recording with fraps it lags alot so i need to lower the quality of the game itself, does this lag mean i need a better graphics card or do i need more ram??
depends on how you have fraps set up... if you limit the fps you will often get more lag but if you dont you will get a huge variation in fps if you have a low end cpu.
dont bother recording at full rez always use half. or better still dont use fraps use bandicam or quobi. bandicam enables a more even spread across the cpu cores so it doesnt affect the fps as much. quobi im about to try for the first time myself.
hmmm forget quobi it has a 30 second max record and watermarks.
steven37
283
Cpu: AMD-8150
memory: 8GB g.skill
MB: Crosshair V formula
GC: diamond HD Radeon 6670 2GB
i can play on ultra high on most games i have like skyrim and blacklight just not when im recording with fraps
