Hello, please help my with my problem
Before all of this, my display were doing fine. Starbound is a 62fps game on a 144hz monitor (current refresh rate is 144) and I ran it without any troubles from I remember.
Now, I've been noticing brightness flickering issues when playing this game, even in minecraft. It is so frustrating.
I did a couple of test like setting my monitor to 60hz and playing minecraft while freesync is on, No troubles
But when I set it to 120hz, the flickering started when I play those games. Even on 144hz.
Flickering disappears when Freesync is set to OFF
Aside from minecraft, starbound, and, borderlands 3, other games works fine.
Problem occurs in
Minecraft, Starbound, Borderlands 3
This happens on 19.12.1, 19.12.2, and 19.12.3 drivers.
Please I hope there is nothing wrong with my GPU, as It really costed me alot of money.
MONITOR: HKC M24G3F, DisplayPort Cable, Freesync Range 50-144
RYZEN 5 2600
RX 5700 XT
TUF 3200 MHZ 16GB
A320 PRO VH PLUS
SEASONIC S12II 520W
Edit: Did a benchmark and I didn't saw any flickering issues (?) the average was 90+ no vsync and only freesync.
Edit 2: Downgraded to 19.11.1, Problem still persist.
Edit 3: setting the fps to more than 140 fps on minecraft removes the flickering, other than than, 130fps down to 10fps has some flickering. So the problem lies maybe on the "Locking the framerate thing" (?). Well Starbound is a 62 fps game so the flickering is there.
Edit 4: The flickering isn't noticable in Starbound when I booted up to my old hdd and flickering is gone when I locked my fps to 60 and as well as in 144 on borderlands 3 but flickering is still there in Minecraft.
I'm really becoming depressed because of this issue. I hope it gets fixed soon. 🙁
Edit 5: I fixed the flickering issue by using CRU and setting the highest freesync range from 144 to 143 STILL, I am not happy. I only think of this as an alternative solution. I wanted to know what is the main problem that this fix, fixed.
In my own Idea, the reason behind this is because my monitor's refresh rate is not exactly 144hz but it's rounded off, from I remember maybe the exact value is 143.xxx where "x" is a 3 digit number that can be rounded off. > (?)
Edit 6: turns it, that fix disables freesync. I'm really depressed and tired at this point for a fix. I wanted to sell my monitor na d buy a cheaper one now. 😭
Edit 7: I tried to use an HDMI cable again (I thought Freesync isn't supported on HDMI cables) and set it to 120hz. The flickering still occurs. Aside from flickers, I get black screen flickers too after just a minute of usage. So it's not the cable?
Edit 8: I tried my monitor with my friend's GPU, still same problem with games but on the freesync windmill demo, I see less flickering on his GPU than mine. (RX 560 PULSE)
Should I say that the monitor is the problem? well we use the same drivers so the last candidates as the culprit is either the monitor or the drivers despite that I used many versions of amd's drivers and still get the same result. How strange...
Problem occurs in
RYZEN 5 2600
RX 5700 XT
TUF 3200 MHZ 16GB
A320 PRO VH PLUS
SEASONIC S12II 520W
