Hello,
I noticed something strange: There's a lag in windows when I hold and drag the mouse for selection rectangle, but only when I keep CTRL or ALT or SHIFT pressed along with the mouse button, there's a lag even with this simple rectangular marquee in windows, the movement gets frozen every 2-3 seconds.
And when I hold and drag for rectangular marquee with mouse button only, there's no lag and it's smooth as it should be.
Same behavior in 3D softwares: lag when using mouse button + ctrl or alt or shift, and NO LAG when using mouse button only
CTRL, SHIFT and ALT are the cause!
But the problem now is how to fix that? I want to use the alt or shift or ctrl key along with the mouse in my 3D apps, it's so convenient and useful.
I disabled tablet input service and it doesn't help
Anyone has a suggestion?
Thank you
Thank you
