Question Freezing, frame drops and stuttering when joining online lobbies or when someone joins my lobby
Sep 28, 2020
So, i built a brand new pc with those specs:
Gigabyte gtx 1650 super windforce oc
Ryzen 5 2600
HyperX Fury 2x8Gb RAM
Gigabyte DS3H motherboard
Gigabyte P650M PSU
WD Blue SSD 500GB
MX330 Case
Phillips monitor
So, from the very first day i built it i noticed that EVERY multiplayer game i play stutters, frames are dropping and the game freezes the first minutes while the game loads the other players, i wouldnt complain if i wasnt the only one, MY BROTHER has a pc right next to mine and doesnt have any issues AT ALL, and he has WORSE specs than mine, so, everything i did was telling me that i dont have any issues and everything runs as expected, well not, cuz i watched reviews of the R5 2600 + GTX 1650 SUPER and they were running smoothly and didnt have any issues at all
And also, i have small stutters in offline games too but the online games ARE HELL
These are the things i did and made no difference AT ALL:
LatencyMon showed no issues
UserBenchmark was showing me that my system runs as expected (My brother has worse results but runs EVERYTHING SMOOTHLY)
I tried setting the game affinity without the first CPU 0 and without Multithreading
I tried setting XMP, disabling HPET from both bios and system
I had an hdd which performed with those stutters and freezes
I tried removing any unnecessary accesories from usb ports and running only with mouse and keyboard
I tried scanning with AVAST, MalwareBytes and Windows Defender, no one showed any issues
I did 2 fresh installs of Windows 10 from my usb and 1 reinstall from the Windows 10 Settings
I tried overclocking my GPU
I have disabled every startup app
I tried clean boot which didnt remove even the offline game stutters
I did CPU-Z cpu stress test which showed that its performing as expected
I tried updating my Audio driver but it was up to date already, i have 2 audio drivers but both of them are up to date
I tried updating my GPU drivers but it made the things even worse
I tried installing chipset drivers
I tried using game boosters
My RAM was never full and never fills up to full for some reason
I tried Empty Standby List and ISLC and timer resolutions
My startup config has all CPUs enabled
I tried doing SFC, scanning for corrupted system files
I tried registry cleaner from CCleaner
I tried doing a fresh install and installing only Chrome, Steam and CSGO but it still was stuttering and freezing the same way
I tried resetting the BIOS settings
I tried changing power plans
The only thing that made a slight difference is Process Lasso with its ProBalance mode but its definitely not the CPU, i think...
NOTES: Ive updated my BIOS, Temperatures of CPU never went above 60°, GPU stays at 70°
Games ive played:
CSGO, Human: Fall Flat, Paladins, BorderLands2, GTA V Online
Im suffering for more than 2 months, PLEASE HELP ME!
