The PC is my familys pc, its something along the lines of an amd xp 2600 w/512 stick of ddr and a geforce3. I built it using parts that I had around and a few new ones probably almost a year ago now.
So the problem: Turn computer on, it'll get to desktop. Let it sit for ~20 minutes and it'll lock up and you get horizontal lines across the screen. If you reboot it, it either won't turn on at all (which suggests overheating and the motherboard protecting you from turning it on while its too hot) or it gets to like the windows loading screen before it locks up and the screen gets a bunch of horizontal lines on it again.
My first assumption was that the video card was shot, so I replaced it with my sisters and that didn't do it. Then maybe I thought it was bad memory, so I tried that without any success. I don't have any other identical motherboards to make any kind of swap to see if its the proccessor or motherboard specifically, but thats really the only other thing to check. Its obviously not the hard drive, and I've checked the other major components.
Assuming that the proccessor fan is 100% void of dust and the case is sufficiently cooled, can anyone think of stuff to try before completely replacing the motherboard and processor? That would really be a PITA :/ Going to post this to a couple forums I visit to see if I can get any good suggestions, thanks for any possible help =)
یί∫υєг ρђœŋίχ
