Hey guys! So i've been having some problems for quite a while now with my PC.It's an old PC because i can't afford a new one at the moment.First of all here are the specs:
Intel Core 2 Quad Q9550 @ 2.83GHz
4.00GB Dual-Channel DDR2 @ 399MHz
2047MB NVIDIA GeForce GTX 760 (Gigabyte)
465GB Western Digital WDC
So i'm not really good at these tech stuff so you gotta bear with me while i try to explain what is going on.The problem started about 4-5 months ago, the boot on the PC was terribly slow, i tried Windows 10 but it didn't work very good so i had to revert back to Windows 7.The boot can sometimes be very slow,sometimes is OK, it varies. In newer games like Wolcen it even froze on the cinematic screen and i had to wait for like a minute, i got into game and it froze again for a minute maybe more, i was able to play for 10-20 seconds before it froze again, launching task manager to end the process also took a while.Sometimes although rarely this also happens in CSGO, random freezes. The first thing i did months ago was run memtest to check if my RAM is faulty, but after running for 10+ hours it detected no problems whatsoever. I tried checking my HDD with a program (can't remember the name,it showed sectors) and all of them were green, so no problem? It's really weird. The HDD is really old, like 6-7 years maybe. I think it's the HDD because when i was playing Witcher 3 and the game was freezing a lot, i remember plugging my sata cable on the HDD off and then putting it back in and after that i could play Witcher 3 fine for some time.I tried another Sata cable aswell but same problems. ALSO, this happened twice,on boot my PC ran a random chkdsk, have no idea why.I tried crystaldiskinfo and these are the results:
View: https://imgur.com/a/WCqeSoi
I honestly have no idea what could be causing the problem.A friend of mine gonna come with an external HDD with Windows installed so we can test it, but i wanted to get your opinion, does this point to a maybe faulty HDD? I also checked the temperatures but they seem fine.
Sorry if i was being unclear, like i said i don't know much about these stuff and tried my best.Thanks a lot!
