My problem is... that yesterday all of the sudden my computer starts to freeze when ever I go to a web site with any kind of multi media. Same for games or anything really beyond just sitting there. It has progressively gotten worse since then.... only thing you can do is basic windows functions without freezes.
PC is only about 6 months old.
Here is my set up.
ASUS M5A99FX PRO R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition
Corsair CX750 Builder Series ATX 80 PLUS Bronze Certified Power Supply
Corsair Vengeance 8GB (1x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory 32 GB
Sapphire Radeon R9 270 2GB GDDR5 DVI-I/DVI-D/HDMI/DP Dual-X with Boost and OC Version PCI-Express Graphics Cards 11220-00-20G
Ive tried narrowing it down. I moved the hard drive to another PC and it works fine.
( I re installed windows just in case..... Still woudnt work on my freeezing PC. )
I moved the GPU to the other pc. ( works fine... no freezes )
I moved the ram ( no freezes )
The only parts I havent moved over are..... the mother board, PSU, CPU.
My CPU isnt compatible with my other PC.
WHAT SHOULD I DO NEXT......
Here is my set up.
