Hello Nvidia's. I am using a Nvidia geforce 9800 gtx+.
i have just gotten the new windows 7 64 bit, but when i try to launch a game, the screen turns black, and my monitor gives me the message.
Frequency Out of Range (for Left 4 Dead, the digits were 74.9khz / 59.9hz.)
It also happens when i launch old games, ones i can play on my old laptop with windows xp.
my monitor is pretty old, so i think the problem is that it cant take a fast refresh rate. Here is, what i think is the specs of the monitor:
Monitor Name : SyncMaster
Serial Number : HJGW904108
Manufacture Week : 40 / 2003
ManufacturerID : 11596 (0x2D4C)
ProductID : 148 (0x0094)
Serial Number (Numeric) : 1297035575 (0x4D4F3137)
EDID Version : 1.3
Display Gamma : 2.40
Vertical Frequency : 56 - 75 Hz
Horizontal Frequency : 30 - 81 KHz
Image Size : 33.8 X 27.0 cm (17.0 Inch)
Maximum Image Size : 34 X 27 cm (17.1 Inch)
Maximum Resolution : 1280 X 1024
Support Standby Mode : Yes
Support Suspend Mode : Yes
Support Low-Power Mode : Yes
Support Default GTF : No
Digital : No
Supported Display Modes :
720 X 400 70 Hz
640 X 480 60 Hz
640 X 480 67 Hz
640 X 480 72 Hz
640 X 480 75 Hz
800 X 600 56 Hz
800 X 600 60 Hz
800 X 600 72 Hz
800 X 600 75 Hz
832 X 624 75 Hz
1024 X 768 60 Hz
1024 X 768 70 Hz
1024 X 768 75 Hz
1280 X 1024 75 Hz
1280 X 1024 60 Hz
my motherboard and CPU is intel DH55HC, and intel i3, and should fit fine. They are completely new parts, and my computer doesn't report other failures like restarting or crashing.
i have made sure to have the latest driver for the nvidia card.
in dxdiag the driver is called: 8.17.12.5896, and at the directory it is called "Nvidia\258.96\WinVista_Win7_64"
Dxdiag says i have directx 11 installed.
What is my problem? Why does all the games want to launch off with this too high refresh rate (or resolution)? i have tried to "Force V-SYNC" in nvidia control panel, because it ought to decrease the refresh to the monitors level, but it didn't help.
Can't find anywhere else in the Nvidia control panel to control the games refresh rate. How can i make the games run slower? do i just need a newer monitor for windows 7? 😵
EDID Version : 1.3
Digital : No
720 X 400 70 Hz
640 X 480 60 Hz
640 X 480 67 Hz
640 X 480 72 Hz
640 X 480 75 Hz
800 X 600 56 Hz
800 X 600 60 Hz
800 X 600 72 Hz
800 X 600 75 Hz
832 X 624 75 Hz
1024 X 768 60 Hz
1024 X 768 70 Hz
1024 X 768 75 Hz
1280 X 1024 75 Hz
1280 X 1024 60 Hz
