I am getting a lot of BSODs even after a few fresh installs. Here is the last one I had:
Below is the dmp and basic system specs. I can provide more specs/info on request.
Summary
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i5 6600K @ 3.50GHz 21 °C
Skylake 14nm Technology
RAM
16.0GB Dual-Channel Unknown @ 1067MHz (15-15-15-36)
Motherboard
ASRock Z170M Extreme4 (CPUSocket) 29 °C
Graphics
BenQ GW2765 (2560x1440@59Hz)
DELL P1911 (900x1440@60Hz)
4095MB NVIDIA GeForce GTX 970 (ASUStek Computer Inc) 43 °C
Storage
476GB ADATA SP920SS (SSD) 40 °C
931GB Western Digital WDC WD10EZEX-00ER1A0 (SATA) 35 °C
Optical Drives
No optical disk drives detected
Audio
Logitech G930 Gaming Headset
* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000000000003a0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8019b6d9449, address which referenced memory
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.14393.693 (rs1_release.161220-1747)
SYSTEM_PRODUCT_NAME: To Be Filled By O.E.M.
SYSTEM_SKU: To Be Filled By O.E.M.
SYSTEM_VERSION: To Be Filled By O.E.M.
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: L1.35
BIOS_DATE: 12/14/2015
BASEBOARD_MANUFACTURER: ASRock
BASEBOARD_PRODUCT: Z170M Extreme4
BASEBOARD_VERSION:
DUMP_TYPE: 2
BUGCHECK_P1: 3a0
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff8019b6d9449
READ_ADDRESS: 00000000000003a0
CURRENT_IRQL: 2
FAULTING_IP:
nt!EtwpLogKernelEvent+49
fffff801`9b6d9449 4b8bb4fc90030000 mov rsi,qword ptr [r12+r15*8+390h]
CPU_COUNT: 4
CPU_MHZ: db0
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CPU_MICROCODE: 6,5e,3,0 (F,M,S,R) SIG: 49'00000000 (cache) 49'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: Wow-64.exe
ANALYSIS_SESSION_HOST: DONNIE_MATX_DES
ANALYSIS_SESSION_TIME: 02-19-2017 12:57:38.0763
ANALYSIS_VERSION: 10.0.14321.1024 amd64fre
DPC_STACK_BASE: FFFFDB817A6F3FB0
TRAP_FRAME: ffffdb817a6f3980 -- (.trap 0xffffdb817a6f3980)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000002 rbx=0000000000000000 rcx=ffffdb817a6f3cb0
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8019b6d9449 rsp=ffffdb817a6f3b10 rbp=ffffdb817a6f3b89
r8=0000000000000002 r9=0000000000000002 r10=ffff868008a5b390
r11=fffff8019b97a808 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!EtwpLogKernelEvent+0x49:
fffff801`9b6d9449 4b8bb4fc90030000 mov rsi,qword ptr [r12+r15*8+390h] ds:00000000`00000390=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8019b7ca829 to fffff8019b7bf6f0
STACK_TEXT:
ffffdb81`7a6f3838 fffff801`9b7ca829 : 00000000`0000000a 00000000`000003a0 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffdb81`7a6f3840 fffff801`9b7c8e07 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffffdb81`7a6f3980 fffff801`9b6d9449 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff801`9b73d538 : nt!KiPageFault+0x247
ffffdb81`7a6f3b10 fffff801`9b6d9363 : ffffdb81`7a6c0180 00000000`00000001 ffffdb81`7a6c2f00 fffffff6`00000002 : nt!EtwpLogKernelEvent+0x49
ffffdb81`7a6f3be0 fffff801`9b6d867f : ffff8680`1310a7c0 ffff8680`1310a7c0 00000000`00000000 ffffdb81`00000002 : nt!KiExecuteAllDpcs+0x393
ffffdb81`7a6f3d30 fffff801`9b7c47a5 : ff2b88e8`50488900 ffffdb81`7a6c0180 ffff8680`086cb700 0000015f`162cf8f8 : nt!KiRetireDpcList+0x5df
ffffdb81`7a6f3fb0 fffff801`9b7c45b0 : 00000000`00000000 00000000`00000000 ffffdb81`00000000 ffffffff`ffe17b80 : nt!KxRetireDpcList+0x5
ffffdb81`7e1b3a40 fffff801`9b7c3005 : 00000000`00000000 fffff801`9b7c1231 ffff8680`138fd800 00000000`000000c8 : nt!KiDispatchInterruptContinue
ffffdb81`7e1b3a70 fffff801`9b7c1231 : ffff8680`138fd800 00000000`000000c8 ffffdb81`7e1b3a58 ffff8680`12effa30 : nt!KiDpcInterruptBypass+0x25
ffffdb81`7e1b3a80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0xb1
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: b0f7750385cc21e9d4ba1773e8e2bcf037f20eb1
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 788dfa2f21d8fb338ed197800570010b546c350c
THREAD_SHA1_HASH_MOD: bc100a5647b828107ac4e18055e00abcbe1ec406
FOLLOWUP_IP:
FAULT_INSTR_CODE: fcb48b4b
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!EtwpLogKernelEvent+49
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 585a2651
IMAGE_VERSION: 10.0.14393.693
BUCKET_ID_FUNC_OFFSET: 49
FAILURE_BUCKET_ID: AV_nt!EtwpLogKernelEvent
PRIMARY_PROBLEM_CLASS: AV_nt!EtwpLogKernelEvent
TARGET_TIME: 2017-02-19T17:04:53.000Z
OSBUILD: 14393
OSSERVICEPACK: 693
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-12-21 01:50:57
BUILDDATESTAMP_STR: 161220-1747
BUILDLAB_STR: rs1_release
BUILDOSVER_STR: 10.0.14393.693
ANALYSIS_SESSION_ELAPSED_TIME: 3f1
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_nt!etwplogkernelevent
FAILURE_ID_HASH: {2dd8433c-c071-e8df-14a1-7a8aa408eedb}
Followup: MachineOwner
