Question Frequent BSOD saying pci.sys system thread exception not handled
May 11, 2025
6
Hi,
I have had the same BSOD for a few months now, and it started off once in a while but its now much more frequent, happening every few times I put the pc to sleep and try and wake it. The pc immediately blue screens on wake and will restart. I noticed that sometimes the pc hangs during POST and I have to force restart by holding the power the power button.
I managed to check online and find the minidump, and tried using windbg but honestly have no idea what I am looking at and how to go forward. I have added the minidump after analysing for someone to help me understand and possibly fix this issue.
The issue happens only when I wake my pc from sleep, I have tested every component and there seems to be no issues, I recently changed the gpu to a 4060ti and only then noticed issues. I have updated all drivers and bios to the newest available, and have changed windows power plan to performance.
Here is the link to the minidumps: Minidumps
Any help is appreciated, I have university work and research tabs that all close when I put the pc to sleep and wake it (BSOD on waking from sleep).
PC: 7800X3D - 32GB 6000 CL30 - 4060Ti - Asus Crosshair x670E
Hi,
I should have mentioned I have updated all drivers from the ASUS motherboard page, chipset from AMD site, DDU and clean install of GPU driver from NVIDIA site and latest BIOS. Blue screen still happening when waking from sleep. I have managed to get the following when analysing one of the minidump files:
SYMBOL_NAME: pci!ExpressSwitchUpdateLinkLatency+11f
MODULE_NAME: pci
IMAGE_NAME: pci.sys
IMAGE_VERSION: 10.0.19041.5789
STACK_COMMAND: .cxr 0xfffffb8bca9c5e40 ; kb
BUCKET_ID_FUNC_OFFSET: 11f
FAILURE_BUCKET_ID: AV_pci!ExpressSwitchUpdateLinkLatency
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {7e259fe8-8750-4604-2aa6-c5ef686562cc}
Not sure what it relates to and I cannot find an answer online for the same error.
Hi,
Have only PBO enabled, everything has run perfectly until I changed the GPU to a 4060ti. No ram or GPU oc. The gpu seems to not cause any issues when put into a different system so I doubt that it's the issue, but I could be wrong. PBO on cpu has not caused any issues and has worked with my old gpu fine for over a year, only now with this new gpu I get these BSOD. I have noticed that the USB peripherals sometimes disconnect, or the network adapter doesnt work until I restart the system and then everything works fine again. I was told its something on the PCI bus thats causing the issue but that was the extent of the information I was given.
Hi,
Will give it ago without XMP and PBO. I did reflash bios before updating to latest and still had the issue, memtest shows memory is good and pbo has worked perfectly until the gpu change. I will try with default settings and report if it happens.
Thank you for your time
Hi,
if the motherboard chipset update does not fix the problem, then you might go into device manager
(as a guess as a fix, from the debug stack)
From Device Manager,
right mouse click on “AMD PCI Express Upstream Switch Port”,
select ->“update driver”
select-> “Browse my computer for driver software”
select -> “Choose from a list of drivers available on my computer”
select-> “PCI Express Downstream Switched Port”.
note: new bios released for your machine 5-6-2025
debugger reports various check sum mismatches with some core files including pci.sys
maybe look for a update for this amd file:
Image path: AMDPCIDev.sys
Image name: AMDPCIDev.sys
Timestamp: Wed Oct 26 22:17:38 2022
best to provide the kernel dump and read the device name to be sure.
looks like the motherboard also has a chipset update
all bugcheck dumps are the same, you need to change the memory dump type to kernel then provide the kernel dump (memory.dmp) file
plug and play is getting some access violation while attempting to make some change.
kernel dump will show the vendor and device code for the failing device. then you can look up the vender id and device name from the code.
most current bugcheck was caused by plug and play attempting to add a device and getting an access violation.
you would need to change the dump type to kernel in order to have the memory.dmp file save the correct info to see what failed to install.
various old drivers installed. ( will look at other dumps in a min to see if there is a pattern)
first three bugcheck are all the same, here is the stack
3: kd> kc
# Call Site
00 pci!ExpressSwitchUpdateLinkLatency
01 pci!ExpressProcessNewUpstreamSwitchPortBridge
02 pci!ExpressProcessNewVirtualBridge
03 pci!PciProcessNewBridgedBus
04 pci!PciAddDevice
05 nt!PpvUtilCallAddDevice
06 nt!PnpCallAddDevice
07 nt!PipCallDriverAddDevice
08 nt!PipProcessDevNodeTree
09 nt!PiProcessReenumeration
0a nt!PnpDeviceActionWorker
0b nt!ExpWorkerThread
0c nt!PspSystemThreadStartup
0d nt!KiStartSystemThread
Machine ID Information [From Smbios 3.6, DMIVersion 0, Size=3715]
BiosMajorRelease = 28
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = 2806
BiosReleaseDate = 02/13/2025
SystemManufacturer = ASUS
SystemProductName = System Product Name
SystemFamily = To be filled by O.E.M.
SystemVersion = System Version
SystemSKU = SKU
BaseBoardManufacturer = ASUSTeK COMPUTER INC.
BaseBoardProduct = ROG CROSSHAIR X670E HERO
BaseBoardVersion = Rev 1.xx
7: kd> !sysinfo cpuinfo
[CPU Information]
~MHz = REG_DWORD 4200
Component Information = REG_BINARY 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Configuration Data = REG_FULL_RESOURCE_DESCRIPTOR ff,ff,ff,ff,ff,ff,ff,ff,0,0,0,0,0,0,0,0
Identifier = REG_SZ AMD64 Family 25 Model 97 Stepping 2
ProcessorNameString = REG_SZ AMD Ryzen 7 7800X3D 8-Core Processor
Update Status = REG_DWORD 1
VendorIdentifier = REG_SZ AuthenticAMD
