I've been experiencing microstutters throughout the whole device, not just while running games, or anything demanding. I've owned this laptop for about a year now and this is the first time anything like this has happened. I've payed attention to the temperature of parts just incase the thermal compound went bad or if theres a lot of buildup but I haven't noticed any concerning numbers and my clock speeds are just fine.
I've ran Latencymon and half the time it says its fine, and the other half it says it has something to do with my ethernet driver (I reinstalled the driver multiple times, didn't change anything). I also reinstalled my gpu driver, also didn't do anything. I saw something similar happen to someone else with a NVMe drive not being properly set up in bios, so I tried to find a setting that they changed in my bios but with my nerfed laptop bios I couldn't find anything.
There is one thing I haven't tried and that is updating my bios, and that's mostly due to my bios saying I have a GS75 Stealth 9SG, which if I go to msi's website, I don't have that version (specs are different). And I'd rather not brick my system by installing the wrong bios update. Anytips to either pinpoint the problem or fix are greatly appreciated.
Here is Specs (MSI website calls it this GS75 Stealth-1074 )
Core i7-9750h
32gb ram 2666
RTX 2080 max-q
Killer Gaming Network E2500 (lan)
Intel 9560 Jefferson Peak (2x2 802.11 ac) (wlan)
Samsung MZVLB1T0HALR-00000 (nvme drive)
Here is latencymon report (when bad):
Conclusion: Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
Core i7-9750h
32gb ram 2666
RTX 2080 max-q
