Question Fresh build behaving weirdly
Bullszeye
36
Hey there, i just did a major PC upgrade and I’ve run into a few issues. The pc boot is slow, takes a little to get to bios. When i turn on the pc the rgb turns on after around 10 seconds. AIO fans sometimes ramp up to max and I see a black screen for a few seconds then it goes back to normal.
Upgraded components are:
i9 12900k overclocked to 5.4ghz with asus AI oc (pulling around 265w on benchmarks)
Gigabyte waterforce 360 AIO
Asus rog Z690-e board
2x16gb kingston fury 6000 mhz ram(xmp 1, set to 6000 mhz clock in bios)
Samsung 980 pro 1 tb
Other (components from previous configuration) are:
RTX 3080 ti gigabyte eagle (350w under load)
Samsung 860 evo 500 gig
Kingston 1 tb ssd
Adata 250 gb ssd
WD 4 tb hdd
Nzxt c850 gold psu (is this the issue?)
3 case fans with rgb (coolermaster h500p mesh case)
Bullszeye
36
20.4 after bios update 0538 -> 1304. What could be the issue here :/ im puzzled, pc now works stable and fine after booting though, screen no longer goes black during usage
