USAFRet :
creepyface5000 :
So as the title says fresh built new computer, wont let me connect to wifi for some reason. It's telling me hey I have to use an Ethernet cable which I cannot. Do i have to install drivers or something to be able to connect to the internet via wifi?
This is a desktop PC?
Did you purchase and install a WiFi adapter? Either USB or PCIe?
Or does the motherboard you have do WiFi? (most desktop motherboards don't)
Yes this is a desktop PC, i have not purchased/installed a wifi adapter im not sure how i would go about doing that since id need internet to install it but you know i dont. and if i did it on another a computer im not sure which one would be the right one to put on a flashdrive
