Question Fresh build has website connectivity problems
gevans166
12
I just built my first computer and so far everything has been going relatively smoothly. After I installed the drivers and updated the bios I then tried to update Windows 10 but Windows says it can not connect to the internet. So I tried Microsoft Edge and that works I can use Bing just fine. The problem is that I can not connect to anything besides Edge/Bing search engine components as an error pops up about the security certificate. I am assuming that is why windows can't update. It should not be malware/viruses as it is a fresh build. My guess would be that something did not download or download correctly but I have no clue what that might be. If any of you have an ideas of what it might be and how to fix it it would be much appreciated.
I downloaded the latest lan driver to a usb and restarted the computer but am still having the same problem.
The OS is Windows 10 Home and the motherboard is a MSI B450 Tomahawk.
