After the build is complete, when I turn it on, the mobo lights up and the fans start spinning. However, I don't get any beeps and the monitor says no display port (the monitor came only with mini displayport to displayport cable, so I'm trying to hook up the displayport end with the mobo displayport and the mini displayport to the monitor).
Went through these suggestions: http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems. The only thing I didn't try is #11, as I'm feeling skeptical to take off the CPU fan (putting in on was the hardest part of the build).
There was no beep speaker with the cabby or mobo, and I'm not sure if there's any inbuilt speaker in mobo. There are some LEDs in the ASUS mobo for RAM, CPU and Display. They turn on momentarily one after another and thrn turn off. I'm not sure what that indicates. When I tried to boot without RAM installed, the RAM led stayed on and other two didn't light up at all.
Also, The ASUS motherboard supports DDR4 and also supports 2666 memory. However, the specific corsair RAM I'm using (DDR4-2666 2X8GB) is not listed in mobo's qualified vendor list. Can this be an issue? I don't have a spare RAM so want to be sure before I get another.
