So I got a new SSD and I wanted to reformat to move my OS and whatever else I wanted onto it. After I reformatted and got everything installed, I've been noticing insane sound issues. What will happen is my sound begins to lag and crack incredibly bad. Everything is distorted and I can't really hear anything. Sometimes if I play a sound or something like that from another app that is open it goes back to perfectly normal. For instance, when I play League of Legends on occasion it will lag at the homepage in the client, but if I click a button there it will go back to normal for a few seconds before returning to what it was doing before.
I use Logitech G930s for my sound which are only USB. Even though they're just USB, I've tried installing the Realtek HD Audio Manager and I also tried installing DFX Audio Enhancer, as I've used it in the past. I have had this headset for a long time, and it has always been plug-n-play. I'm not sure if its something wrong hardware-wise or I am some how missing some crucial drivers. Initially I thought that it was drivers, but everything I have done so far hasn't changed it. As for hardware, my computer isn't old much at all.
Just a quick spec rundown in case it helps
Operating System
Windows 10 Pro 64-bit
CPU
AMD FX-6100
Zambezi 32nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 799MHz (9-9-9-27)
Motherboard
BIOSTAR Group A960G+ (CPU 1)
Graphics
HP L2045w (1680x1050@59Hz)
HP LE2201w (1680x1050@59Hz)
2047MB NVIDIA GeForce GTX 660 (EVGA)
Storage
465GB Western Digital WDC WD5000AAKS-00V1A0 ATA Device (SATA)
931GB Western Digital WDC WD10EZEX-60ZF5A0 ATA Device (SATA)
167GB INTEL SSDSC2BF180A4H ATA Device (SSD)
Optical Drives
No optical disk drives detected
Audio
Logitech G930 Gaming Headset
Thanks for the help,
Jon
Operating System
CPU
AMD FX-6100
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
Jon
