Fresh Reinstall, Mouse not working
billin30
254
I just reinstalled XP on one of my computers because it had some problem. It is a dell E1505 laptop. Got windows loaded and started doing the drivers.
I got to the chipset driver they suggested and after it was done installing, my mouse no longer worked and I had to use the touchpad. Looking at the Device Manager, it looks like some of my usb hubs are not active. I tried plugging the mouse into all the ports and nothing happened. It is just a dell standard mouse, so it shouldnt need any additional driver support.
I installed the ATI drivers as well and when I reboot, i keep getting this cli.exe error. I just went to msconfig and stopped that from starting up and no more error. Just wondering if that is going to be a problem.
So far no other errors, but this is the second time ive reinstalled windows on this machine and I dont remember so many problems the first time. Just wondering if I did something wrong...
Thanks for your help.
Z
pat mcgroin
1,687
60
before you reinstall anything go into the bios and turn on legacy usb support.
I have had some computers where that is the only way to get a usb mouse to work.
Also there could be another driver for usb for that model.
Some computer require it and others dont.
A double check cant hurt.
Similar threads
