Blt1684 :
Okay, so I just rebuilt my PC, basically from head to toe. I already had a GTX 980ti I purchased about a month ago, which influenced this system upgrade. So yesterday, I just got all my parts in the mail for my PC upgrade: Asus ROG Maximus VIII Hero mobo, Intel i7-6700k CPU, Samsung 850 Evo 500gb SSD, GSkill DDR4 3200 8gb (4x2) Ram, and Cooler Master 212 Evo Heatsink. So with all parts installed, the systems posts and I install windows 7 onto fresh SSD. I lauch windows and install all drivers, also installed Blade and Soul then played it for a while. Then I decide to install Aion. After I install, I launch and the heatsink fan spools up pretty fast and then bam... BSoD. I thought, oh well I know sometimes these can just happen for no reason. So I try again and bam... BSoD at the same moment. Its happening right after the loading screen gets to 100%, the heatsink fan spools up fast and then blue screen. I thought it might be my ram, so i remove one and repeat the lauch process. Still I get BSod. So i remove the other and same thing. So I happen to have a new 250 Sandisk SSD laying around, so I remove the 850 Evo to see if it is the problem. I install windows 7 and all hardware drivers (lengthy process) onto new Sandisk SSD. Then I install Aion on new SSD and same BSoD. So i then swap out my 980ti back to one of my 660ti gpu's and still BSoD on Aion launch. The only other two items i have is the new Maximus VIII Hero Mobo or the new i7-6700k skylake CPU. But these are all new items and I know that you can in rare situations recieve bad parts straight from the vendor (my first 660ti had to be RMA'd) but it is rare. Also i should add that i installed bluescreenview software and it kept showing that the fail was coming from ntoskrnl.exe driver. I did some research and that usually has to do with memory. But, ive checked both the ssd and the ram, unless i did not test well enough then they both seem fine. Ladies and Gentlemen, I am at a loss. Please help me.
"Loading Dump File [C:\Windows\Minidump\032016-5787-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available..."
That's usually caused by a bad driver. Try other drivers from the original manufacturer / device maker website.
How did I guess you had an Asus MB?
I suggest you change to another type board. I suggest Gigabyte or Intel.
Then I would guess all the problems are over(?) (bet you $1)
See, Ive been thru this before....and I learned it was far better to just use a different motherboard, rather than screwing around for hours/days trying to make the Asus board work...just a suggestion.
But this advice may save you a great deal of frustration.
When installing software / drivers / updates
I suggest you turn all security and firewalls OFF.
Test your install, restart the computer, turn security back ON.
Security can block (parts of) certain installations.....
But ultimately, I think you will come to the conclusion that I reached.
A. When these power saver features are enabled, it causes a bunch of problems.
B. Windows shuts down your system to sleep, hibernate, standby, etc..etc...
C. After shutting down system to "save power" the system malfunctions when you try to wake it up again...and locks up, freezes, etc...
It locks the mouse, it locks the keyboard, it shuts off the display, and locks out the hard drive, it shuts off USB devices, etc...etc...
D. This will cause you to pull your hair out, and go to the funny farm...(those nice young men in their pretty white coats)
E. Make it stop, please make it stop.
F. Shut off all these "features" and USE your computer for a change):
Click Start, Click Control Panel,
Look at the top of the window, in the path bar you see “control panel >”
Click on “>” (in the path bar) now click on “all control panel options.”
(This will open up all the hidden controls available)
Click Power Options
click on the arrow to “show other plans”
Check the Box that says "high performance"
Click (in high performance) "change plan settings"
Turn off display: set to NEVER
Put the computer to sleep: set to NEVER
Click: Change advanced plan settings
Scroll down the list: Click on the + signs to expand the choices for each item on the list.
Require a password on wake up: set to NO
Hard disk: turn off the hard disk: set to NEVER
Wireless adapter settings:
Sleep: set to NEVER
Allow Hybrid sleep: set to NEVER
Hibernate after: set to NEVER
Allow wake timers: set to disable
USB settings:
USB selective suspend setting: set to NEVER
Power Buttons and lid:
Power button action: Setting: set to shut down
Sleep Button Action: set to: do nothing
PCI Express:
Link State Power Management, Setting: OFF
Processor Power Management: Minimum state (set to) 7%
System Cooling Policy: setting: Active
Maximum State (set to) 100%
Display
Turn off display after: setting: NEVER (turning off display automatically can cause freezing also)
Turn off the monitor power manually, when you want it off. Don’t use the auto monitor turn off.
Multimedia Settings:
When Sharing Media: Setting: Prevent idling to sleep
When Playing Video: Setting: Optimize Video
Click APPLY
Click OK
Open the bios set up and make sure "cool and quiet" is OFF. (AMD)
If there is a power saver or a "quiet mode" in the bios, shut it off...
There may be a performance setting in the bios setup you have...make sure it's cranked up to max.
in the bios, see that the allocation for video, if available, is maxed.
Now open the hardware manager profiles...
click start
click computer
click system properties
click device manager
double click on mice and other pointing devices
right click on HID compliant mouse
left click on properties
click on the power management tab
UN-check the box that says: "allow the computer to turn off this device to save power." (there is now NO check mark in this box)
click OK
Now repeat this procedure for all mice, monitors, keyboards, and ALL USB ports on the device manager list.
You must open ALL the devices one at a time, as above, and turn off the power saver, for each device.
NOW turn all the security back ON. NOW open your security antivirus. Make sure the antivirus is set to "gaming mode." Or "multimedia mode."
This prevents the security updating from interrupting your game / multimedia priority.
IF the security does not have "gaming mode" or "multimedia mode" get different security.
IF you are using "free" security downloaded from the internet, get rid of it NOW.
Use ONLY professional all in one security. DO NOT load multiple mismatched security programs, which conflict with each other.
DO NOT load free tools into your system such as: "driver sweeper" or any of that "free" goofy stuff.
