i5 12600k
GTX 3060 Ti
Corsair RM850e
MSI z690 Tomahawk Wifi DDR4
I built it yesterday, and was using it perfectly fine for several hours. I even ran benchmark tests and everything was operating well within range across the board. I was watching some videos some hours later and the PC suddenly lost power. I couldn't turn it on at all, even after unplugging power and back in, changing plug sockets, nothing. I eventually started taking out PSU cables to see if it would power anything on and I found that as long as my GPU isn't plugged into the PSU, it will power on. If I attempt to power it on with the GPU plugged into the PSU, nothing will happen besides an instant of power. I will then have to unplug the PSU, then unplug and plug back in the Motherboard PSU cable before it will start again, but everything runs perfectly smoothly if I do. As soon as I attempt to plug the GPU back in, nothing happens.
I tested plugging the GPU in but unplugging the CPU, but it still didn't work, which I figured would be the case because if it was a PSU power supply issue it would have not worked in the first place for several hours. I also reseated the GPU but that made no difference. The lighting on the GPU works even when the PSU isn't connected to it though so it's not like it's completely dead.
It was a used GPU but it was in working condition when I installed it, and I did not modify or overclock the GPU at all, only the CPU within safe ranges.
What should I do? I have no idea how to fix this issue and am debating just filing a return as faulty as I bought it off ebay a week ago but I'd rather ensure it is nothing else or nothing I can just fix/diagnose myself.
https://streamable.com/eq8fh2 This is a video of what happens when I attempt to start the PC with the GPU plugged into the PSU.
GTX 3060 Ti
Corsair RM850e
