Hello Everyone,
After a year and a half of heavily using the build listed below, (rendering 3D’s with Sketchup, Lumion & using Photoshop (all at the same time)) the PSU (Corsair CX600) has died whilst I was using photoshop & InDesign, frying with it my motherboard (Gigabyte Z87-D3HP).
I would like to ask whether a power surge would have been likely to cause the issue, or possibly was it due to the PSU’s (poor?) build quality, which has died ‘naturally’.
A local technician told me that a surge could have likely been the culprit as they tend to occur every now and then where we live, especially in the summer when the electricity demand is high due to our very hot climate. Supply is around 230V-240V but may vary up to 250V in some areas.
He also said that the PSU should have been of higher wattage (750W) to support my 4GB Palit Nvidia GTX 770 VGA. I pointed out that the PSU lasted for 1.5 years prior to this incident. Shouldn't it have failed to supply power to/fry my system way earlier?
NOTE:
I have contacted Corsair for a replacement and asked if I could pay for an upgrade, but they declined and will only offer another CX600. Before accepting and paying postage fees to return the faulty PSU, is it wise to use the CX600 again or is it better for me to invest on another PSU, say EVGA SuperNOVA 750 Watts B2 80+ ?
BUILD:-
CPU: Intel Core i7-4770K (4x 3.5Ghz/ 8mb L3 Cache)
Cpu Cooling: Cooler Master Hyper Tx3 CPU Cooler
RAM: 16GB (2x8Gb) DDR3 1600MHz Dual Chnl. Mem. Kingston HyperXBlu
VGA: Palit Jetstream Nvidia GeForce GTX 770 4GB 16xPCIe 3.0
MOBO: Gigabyte Z87 – D3HP
HDD: 2TB SATA III 6.0Gb/s 7200 RPM
Optical Drive: 24x DVD/R/RW
(3.5” drive bay): 12in1 Flash Media Reader/Writer
Network Card: PCI-E WLAN 802.11n 300Mbps NIC
Fire Wire: 1394a FireWire 400 PCI card
PSU: Corsair CX600
Thanks everyone!
Confused Joe
NOTE:
BUILD:-
PSU: Corsair CX600
Thanks everyone!
Confused Joe
