Hi,
I built my own system with a GIGABYTE H87M-D3H motherboard and all went well. Almost everything was connected, the system was running, leds on, fans on, hdd working, I even installed Windows on the hard drive, etc.
At some point I turned off the pc (and PSU) and tried to connect the last wire that was unused, i.e. a wire coming from the case with the letters (VCC D- D+ GND GND). I put it on the F_USB1 connector of the motherboard which has two rows of 9 pins total (four pins at first row, five pins at second row). The (VCC D- D+ GND GND) wire has 4 pins and I put it on the first row of the F_USB1 on the motherboard (that's what I read online).
So after that I turned on the PSU, and then the pc. It turned on for one second and it went off.... Now no matter what I do (I removed many of the cables in the m/b) I can't turn on the pc. Nothing happens, no leds, no fans working, nothing.
Does that mean that I connected incorrectly the VCC D- D+ GND GND wire and damaged the motherboard?
