Friends can hear my volume and all my music PLEASE HELP!!!
efmaniac
7
I recently just got the MSI 970 Gaming motherboard and ever since my friends are able to hear all my volume from everything im doing, if i'm playing a game, or listening to music they can hear me, ive tried everything I can and I dont know what to do, i've looked up how to fix this issue and ive dont what people say and there is no fix, someone please help!!
When you mean "your friends can hear you" you mean through a VOIP program like SKype? What VOIP are you using, as for communication are you using a headset? Please help us understanding better.
I am using headphones, and im using Discord, whenever I am listening to music or playing a game, they can hear the volume of my game and hear my music, and they always tell me to fix it and idk how to. Hope that clears things up :)
At Discord settings there's a few options that you can enable at "Voice - > Advanced Tab", regarding "noise removal" "echo removal" and such, have you tried enabling those? Also check if your headphone "ouput" volume is slided to 100, I don't mean the "main volume" that you listen but the volume that you can enable to be reproduced by your speakers or any audio device just like a Microphone, try also checking that at "Sound" settings on your Windows Control Panel. "Right Click on the Device, then click on "Properties" and check if there are extra options enabled, if you don't know what each one of the settings does please do post your "sound settings" print so we can figure it out what's going on. Also I'm not sure what Headphones are you using but does it comes with a audio card built within that has separate drivers or panel to tweak settings? If so, try checking that as well.
Hi thank you for responding, i tried everything you asked and it did not help, and I am using kingston hyperx cloud and i dont know hot to check if it has seperate drivers or a panel to tweak the settings
