[SOLVED] From 1050ti to 1070
Jul 9, 2021
Hey! I have a Asus aspire gx 781 (old af I know but I don't do gaming that often). Is it possible to upgrade from a 1050ti to 1070? I Know it depends on the motherboard and power supply but I have no idea how to check these things. Also I kinda figured I can replace the i5 7400 with a i7 7700 since they have the same socket type but kinda need confirmation on that also
If it matters some specs
Intel i5 7400 3ghz 6mb chipset h110
Gtx 1050ti 4
8gb ram ddr4
And note that checking the PSU will almost certainly require you to open the PC and physically look at it. There's no real shortcut here since it's a PSU you didn't buy and install.
I think you mean an acer aspire…
a gtx 1070 would need an 8 pin pcie connector and a minimum 500w psu. You must first confirm if the psu has one, and meets the minimum wattage.
Thanks for the answers! Will definitely open it up and see what kinda psu it has. Yeah it was offered with the 7700 and afaik it should go right in. Ram was the other thing also that I seriously need to upgrade
