From 1600 MHz To 1866 Mhz?
If the sticks are strong enough Yes. Most any DRAM of good quality can be OCed up a step, i.e. in your example from 1600 to 1866, simply manually set the DRAM freq up to 1866 in the BIOS, and raise each of the 4 base timings by 1 i.e. if your base timings are 9-9-9-27 then try 10-10-10-28 and increase the DRAM voltage + 0.05 - what model DRAM do you have and could prob be more specific
Is GSKILL RIPJAWSX 8GB 1600MHZ (F3-12800CL10S-8GBXL) strong enough?
