From 900p to 1080p: 20 FPS less?
osorius
34
Greetings folks,
I've been playing in 900p for a long time. However, I just upgraded my rig and wanted to try playing on a 32" fullHD TV. The results as the title says is 10-20 fps less. Where I got constant 55-60 fps, now I got 45-50 fps, depending on the game... Is it normal that much performance loss?
My rig:
♦i5-3330
♦R9 280 Windforce
♦8Gb 1600MHz
♦GA-B75M-D3H
♦Corsair TX650
Thanks in advance.
Yup spot on. If you dont notice much difference in performance when going up a resolution, then the it was not the GPU limiting performance. Thats not to say your CPU is bad, but there always has to be something limiting performance.
I got a 10 fps drop on Tomb Raider (maxed out). At 900p I get 50-60 fps and at 1080p I get 35-50.
Watch Dogs with the Worse Mod gave me a good boost with most settings on Ultra. 900p with 30-60 fps, and 1080p 20-50 fps.
Bound By Flame I get a constant 60 fps at 900p and at 1080p sometimes 40 fps.
These are all "old gen" games. I guess upcoming games will give a hard time to the R9.
Sorry to resurrect this topic but I'm getting pretty confused with this 900p -> 1080p thing...
Older games:
I tried playing The Witcher 2 on both resolutions, everything maxed... Strangely I get unconstant 40-55 fps on 900p and on 1080p... constant 60 fps (???).
Dragon Age 2 the same as Witcher...
Newer games
On Crysis 3 though, I get a 10 fps drop from 900p to 1080p. I had to lower some settings to play.
Tomb Raider the same as Crysis
Watch Dogs I get only a 5 fps drop.
To conclude... Do older games get better performance on higher res. and newer games loose performance on higher res. (some more than others)?
So, is resolution performance really a matter of GPU or game optimizing? Or something else I'm missing here?
Thanks in advance
Its quite simple, the higher the resolution, the harder work it is for the GPU to render (because of the extra pixels).
This is why even high end cards struggle with 4K, because its just so many more pixels.
Some older games might be more bottlnecked by CPU performance, not GPU performance, hense there being little difference when you increase the resolution (resolution makes no difference to CPU workload, it remains the same)
