Hey, guys, I have the NZXT S340 Elite case. As you guys know, this case has a closed front so the intake is limited. My current set up is a 240mm front radiator as intake, 120mm back fan as exhaust and and a top 140mm as exhaust.
I was wondering if having the from 240 rad as exhaust and the top 140mm as intake and leaving the back as exhaust make any difference?
This is the current airflow set up:
This is what I'm asking if it would work:
As you can see I have water cooled GPU as well so the only thing that would need some air would be the motherboard and its VRM's but the top can provide it if placed as intake, no?
Just wondering if it would make any difference. But then again the front is very limited so the hot air would probably not dissipitate much?
