Front 3 pin fans unable to be controlled despite motherboard capability.
zackman500
5
Earlier I upgraded to an SSD from an HDD, and after installing all the drivers and everything, my front two 3 pin fans that were able to be controlled prior to the upgrade via the motherboard no longer have the option to be controlled. I have searched through the Bios and AI Suite 3 to see if I could get anything working but no no avail. They are quiet upon booting up and entering Bios, but immediately start up to 100% (1200 RPM) as soon as Windows login screen is ready, and there is no way for me to control it. In BIOS they run at around 900 RPM and they're fine, but otherwise, no dice. Any help?
I'll try uninstalling it and reinstalling it tomorrow, and I'll get back to you on if it works. I'll uninstalling it, restart, see what happeneds, then reinstall it and see what happens.
Uninstalling it fixed the issue. i am gonna download the latest AI suite from Asus and try to get both to work. If not, then I'll leave AI Suite Uninstalled.
