Front audio connections
beario
i have just built a system with a ezcool m-60b 500w case and a gigabyte g31m-es2l mobo the problem i have is that there is one green wire that comes from the front panel with an eyelet for a screw on it that i dont know where to connect it to any help would be appriciated
no manual in case when it arrived so i connected to the case if u trace it back it goes into the front audio jacks but can't see where too as its enclosed in a plastic case
Does anyone know if they make a front panel audio extension cable so I can route it behind the motherboard tray. The one that came with my case is too short.
too new to this selfbuild game too answer that have to ask someone with more nouse
