Hello, I'm trying to set up my front panel audio connection with a Antec Sonata III case on a Gigabyte P55-UD3R motherboard. However, I'm not experienced in doing so and something seems to be wrong (as plugging in my headphones to either jack in front while audio is playing does nothing).
I do not understand how to use the Pin No./Definition tables given in both the Antec manual and my Gigabyte manual. I've located the pins on the motherboard and plug in the HDA cable (AC'97 does not yield any sound either, and I would rather HDA) so that all pins in the header are in. I looked through the BIOS and did not find anything notable pertaining to audio, other than Azalea codec options. I installed GIGABYTE's drivers and nothing.
I've tested the headphones in the rear port (where a box will pop up confirming I have plugged them in, as it should) and they work fine. However, in the front, nothing happens. In the "Realtek HD Audio Manager", no change seems to yield a function in the front panel.
Any help is much appreciate; I posted this in the PC Cases forum and someone advised me to post here (I guess it is appropriate as this would seem a GIGABYTE issue).
