hi
i have pentium d 3.2 gz processor and the tempreature shown on the bios mode hardware monitoring is very high. it reaches quite higharound 68 C (after applying new thermal paste before it was around 78 C). does installing a case fan lower its tempreature.
in my digicom case only one extra 80mm fan with 3 pin connector be used on the front side of the case which lies directly ahead of graphic card(galaxy gts 250 1gb). should i use the fan to flow air inside the case or draw air outside from it? i.e should i blow air inside or outside of the case?
