Alright so i woke up 2 days ago and noticed my Front case 200mm fan wasn't spinning I gave it a light love tap and it started spinning at its regular rpm. My hard drive temperature usually is 30 degrees on idle and load since it never spins down but that day it was 33 degrees celcius. my ssd was 24 degrees as usual.
It the fan has been spinning normally again for 2 days since and the temperatures in my case are normal aswell. Also the fan hasn't made any wierd noises either
Temps are celcius
cpu idle 35 and 44 load
gpu idle 30 and at 100% load its around 75 degrees with a fan profile of 80%
room temperature is around 22
Is the fact that the fan wasn't spinning that day something i should worry about? And what could be the cause? There is no dust in the fan and it gets cleaned monthly. Sorry for asking this but I havent been able to keep it out of my mind since. I do have a fan controller on the fan and i can speed it up and slow it down as normal. Should I be worried?
Temps are celcius
