front headphone and microphone slot not working
fuchs
50
Hello
can help me?my front headphone and microphone not working
slot on back working,but i put speaker jack there
Check the wiring. Probably the connector is not in its place. If you don't know where to connect then check you motherboard manual or just follow the wire going from your front headers to the motherboard.
i check everything ,but i donno it correct or not lol
and i just notice front usb also not working
but everything on the back work fine
SOLVED!!
go to control panel,search for Realtek,click on it,find folder icon top right,check disable front panel jack detection
i dont know what it do,but it work lol
