My case is the Gamemax Polaris and unfortunately it doesn't have a top mount for a radiator. However, it says that the case is compatible for a front-mounted 240mm radiator. I was wondering if I can still use my case fans in a push/pull configuration with my NZXT Aer fans. The 240mm cooler I want to mount at the front of the case is the NZXT Kraken X52.
I love my case and love its lighting and if it is recommended I change my case fans to RGB static pressure fans, I will do so.
