[SOLVED] Front panel Aerocool Cylon Mini
Jan 4, 2019
5
Hi!
I recently bought the Aerocool Cylon mini, and I wanted to know if it is possible to remove the front panel (I don't know where to install the front panels fans), and if it's possible, can you tell me how?
Thank you,
LeTiti
Does the following link match your case?
https://www.hardwaresecrets.com/aerocool-cylon-case-review/2/
If so, scroll down to between Figures 3 and 4. Text states to just pull the front panel.
If not your case then look for the applicable case User Guide/Manual.
