Front panel, audio and USB connection between MOBO and case!
romethaug28
112
Hey. My motherboard is:https://www.amazon.com/ThinkCentre-Desktop-Motherboard-03T8351-IS6XM/dp/B0188ZJX8I and case: http://ibox.pl/en/cases/1732-force-1810.html. These 2 have different connections. Is there anything i can do. if i cant and i wont be able to connect these things. Can i use the back panel´s audio and mic jack. And usb ports only. Or are the front panel things MUST HAVE? This is my first PC. all the other things matched. These are the last things. And the things i didnt think of.
All help is adviced!
Thank you!
Only front connections to Start and Reset buttons plus LEDs (partially) are "Must have" in the front of the case, sound and USB are not.
