I need help with my front panel audio connectors. My mobo is Z68 gigabyte XP-U3DP. I have read the manual concerning the audio connectors but followed the instructions and my front panel headphone still doesn't work.
I have no idea what my case is since there is no model # inside or outside the case since i'm reusing it from 2005.
My case has these front panel audio connectors
R-Out/R-Ret (1 wire 2 pin holes)
L-Out/L-Ret (1 wire 2 pin holes)
Mic In/Mic Vcc (1 wire 2 pin holes)
Ground (1 wire 1 pin hole)
What does NC mean in the motherboard manual??
http://download.gigabyte.us/FileList/Manual/mb_manual_ga-z68xp-ud3p_e.pdf
page 27
page 27
