Hello I 've got an issue. I am trying to get front panel audio to work. I opened the case and I found the place where the 9 pins of the front panel should be connected, and -guess what!- it did not have any pins on it... Then, I found some unplugged pins into the case but there is a problem here: they are only 5 pins!: 1 Audio2_L, 1 Audio2_R, 1 Audio_Ground and 1 Mic2 and another one..... I guess they are dedicated to the front panel audio, because the wire which contains them all comes from that the front panel region of the pc. I need your help!
System:
Motherboard Gigabyte GA-G41MT-D3
PC Case Sunbeamtech Trio
System:
